Limp mode. TIPM replacement did not help, any suggestions? Trying to avoid dealership
- Vehicle: 2016 Jeep Wrangler Unlimited Sport S
- Mileage: 91k
- Symptoms
- When shifting out of Park
- Lurches forward/backward with significant force
- Limp mode
- Will not shift out of 1st or 2nd gear
- When selector is in Drive and I push to right (to see which gear it is in, or shift up/down “manually”), nothing happens
- Occasionally when I’m driving it around town to troubleshoot it will all of a sudden start shifting like normal again
- Blinking defroster light
- When first starting, lasts ~15 seconds
- Engine codes
- In early December, Jeep was running fine but engine codes popped up. I cleared them and these specific ones did not return to my knowledge. Maybe not related?
- P0303: Cylinder 3 Misfier
- U0414: Implausible Data Received From FDCM (had 3 of these)
- Second week of December limp mode started, so I immediately took it to my local shop (non-dealer)
- They said TIPM was bad and I need to replace. Might also have other transmission problems, but wouldn’t know until TIPM fixed. Quoted ~$1500.
- They told me codes they pulled were: C1405 (transmission code), B1630, B1620, B1638, B1634 (all power loss codes)
- Second-third week of December
- I’ve tried doing my own troubleshooting. When I do the “on-off” 3x trick to get engine codes on dashboard, nothing shows.
- When I go to another auto parts and borrow their scanner, now I usually only get U0414 codes.
- Repairs attempted
- I purchased a rebuilt TIPM from Maks (HOME) and have installed it. Did not fix any of the issues.
- Have not had a chance to pull codes with a scanner, but the “on/off” 3x trick still shows no codes, yet engine light is definitely on.
