Linex'd jeep, Now seatbelt chime.
Put jeep back together after LineX and now I'm getting intermittent seatbelt light/chime.
I had an airbag light for a few days-I re-secured the small yellow connector by the rear driver side door on the floor, but now the seatbelt lite/chime pop up.
I do have side airbags. It's a 2011 Jku
Does anyone know which of the yellow connectors is responsible for knowing if the seatbelt is engaged?
Any ideas?
Any ideas?
Put jeep back together after LineX and now I'm getting intermittent seatbelt light/chime. I had an airbag light for a few days-I re-secured the small yellow connector by the rear driver side door on the floor, but now the seatbelt lite/chime pop up. I do have side airbags. It's a 2011 Jku Does anyone know which of the yellow connectors is responsible for knowing if the seatbelt is engaged? Any ideas?
Maybe
I always use a small amount of dielectric grease on electrical connections to ensure continuity and reduce oxidation of the contacts.
Guessing if you have an "extra" connector below the seat it may be for heated seats (if you don't have that option). Sorry if this is not helpful, just hoping you get it figured out.
