Lookkng for switched fuse for tap a fuse in fusebox.
Hello:
I am in the process of installing winch interior switch. I need a switched power sources in the fuse box. Will use a tap a fuse. 2013 Jku rubicon.
Thanks in advance.
Thanks in advance.
how about the switched power outlet on the dash?
https://www.jk-forum.com/forums/jk-e...ighter-254452/
I forget the fuse number but you can find it in the owner's manual. The fuse for the sub-woofer can be flipped from switched to unswitched, the position you'll find it in if you don't have the powered subwoofer option.
So I don't have heated seats. There is empty for read fuse block and a fuse in front heated seats. I am going to use one for my warm winch power interupt switch. Would it be okay to use the other for rigid duallys. They are not the d2s so draw very little amperage. I think it is 1.1 Amps per light. I would think less then a heated seat. Thanks in advance.
