Map lights won't turn off on rear-view mirror
Old 07-17-2022, 07:31 AM
resharp001's Avatar
Received 1,827 Likes on 1,597 Posts
Nope, I gave up on my '13. Was not worth the effort for me. For whatever reason the CANbus on the '13 just never liked LEDs in the dome lights, even "CANBUS-friendly" LEDs that I've seen. Maybe others have found something. I just didn't care enough.
Old 07-17-2022, 09:15 AM
FH02rner's Avatar
So what did you do to turn them off?
Old 07-17-2022, 12:51 PM
resharp001's Avatar
I didn't use LEDs. I just stuck with the regular bulbs from the factory. It's not like they give off less light IMO, it's just warmer yellow rather than cool white.
Old 07-17-2022, 01:51 PM
Tazzinator's Avatar
I own a '13 JKU and just recently made the change to interior LED's. Since then, the map lights on the rear-view stay on. Doing some research, I found this thread on JK Forum that appears to be a couple years old and wanted to see if anyone has found a solution other that turning the map lights off completely? Perhaps Jeep has an answer?
Same,same. I believe if you put a resistor on the interior lights it will solve the problem, but I haven't tried it and I'm not planning to. It's working just fine for what I wanted and I don't think those mirror lights do that much anyway.
Old 01-26-2024, 01:32 PM
James_V's Avatar
I now have the same problem, except I put LEDs in the rear of the Jeep years ago. The map light problem started just after my windshield was replaced. 😒
From what I've seen, there really isn't a resolution aside from changing the now old LED's.
Quick Reply: Map lights won't turn off on rear-view mirror
