Map sensor
Two of the three wires end up at the TIPM, connector C2, and one at connector C1, but there is a connector somewhere in between.
At the TIPM- MAP signal is position 23 in connector C2.
At the TIPM- MAP ground is position 27, connector C2.
At the TIPM- 5 volt supply is position 27, connector C1.
PM me if you need more detailed information.
Here is a picture showing where TIPM connectors C1 and C2 are located:
