Max woofer diameter behind kick panel?
Old 07-20-2016, 11:25 PM
nevillebartos's Avatar
Default Max woofer diameter behind kick panel?
I've got 6.5" in right now, anyone managed to get anything bigger in? Hoping someone might know as looks like a real PITA to gain proper access behind there.
Old 07-21-2016, 08:14 AM
Mattk11's Avatar
Do you mean in the pods?
I have 6 3/4" Focal woofers. You could probably fit up to 7" but the internal volume of the pod is too small for even a 6" woofer. Going bigger won't necessarily give you more bass. A proper subwoofer is about all that will help.
Old 07-21-2016, 02:48 PM
Thanks mate. Any idea if there'd be space for a bigger pod? I run 2 subs in the back already, looking at going 3 way up front and was just planning to go with another 6.5" woofer, however if there's a chance of say an 8" I'd look into how that might work out. My subs are 12s though so 6.5 seems like it'd be about right anyway - 6 3/4 is good to know as it might work out to be that.
Just swapped out the HU again, acoustic treatment is next then another amp and the 3 ways. This is the sub box I had done a year or 2 ago, makes great use of the cargo space. Will have the same guys do a dash pod for the mids and tweeters, if there's space and I landed on a larger woofer I'd see if they could knock something up to sit behind the kick panel.
Old 08-17-2016, 03:45 PM
BajaYeller's Avatar
[QUOTE=nevillebartos;4233577]Thanks mate. Any idea if there'd be space for a bigger pod? /QUOTE]
I was just digging around in the speaker pods this morning. There is plenty of room on the driver side to put a larger pod in, but the passenger side pod is quite small. On the passenger side, the pod is already as large as it can be without doing something like removing the glovebox. It runs into the glovebox on the left and the frame of the dash on the right. The biggest 6.5" sub you can fit in there is the Tang Band W6-1139SI. It has a skinny magnet, but still needs a mounting spacer to give you the clearance.
I was trying to figure a way to 3D print bigger speaker pods, but my 2015 jk is already maxxed out on the passenger side.
http://www.parts-express.com/tang-ba...oofer--264-832
Quick Reply: Max woofer diameter behind kick panel?
