Morimoto D2S HID Projector Retrofit
Old 04-19-2012, 10:01 AM
03HDFB's Avatar
Nice work!!!
JUst started my own little project like this too. Been running HID's in everything since I picked up my jeep....Now its time
to make them projectors! I'll post up when I'm done!
Again...Nice work!
Old 04-19-2012, 10:03 AM
Mr Rubi's Avatar
well done! and I like your user name, pretty cool.
Old 05-03-2012, 09:01 AM
arjeeper's Avatar
Very nice install. The light output looks phenomenal!!
Old 05-03-2012, 09:32 PM
Ten2ndNova's Avatar
This will be my next mod, for sure...
Old 05-04-2012, 07:49 AM
kingrye's Avatar
Hey, I plan on retro fitting into these: How much of a rear space issue do you anticipate I will have? (i know you dont know the measurements, but what do u guess?) I will prolly also cut these down so that the rear of the projector is exposed...
http://www.123mercedes.com/files/w463_headlight_005.jpg
Old 05-21-2012, 05:28 PM
Ominx's Avatar
Sorry I took so long to reply. Do you plan on just using the housing from the G Class or just the projector? Looking at the projector itself, I think it should fit without a problem.
Old 05-21-2012, 09:06 PM
kingrye's Avatar
at first I plan on moding to mount on the jk with the current halgen projectors then some day swapping ds2 projectors in
Old 06-20-2012, 05:11 PM
CobraMarty's Avatar
I tried the oven 275* for 8-10 minutes and no luck. Glue would not budge. Any other ideas?
Old 06-20-2012, 06:07 PM
Ominx's Avatar
There are two things you could try that may help.
1. Use a heat gun to soften the locking tabs and then pry them back a little until the release. You will have to reheat them when you reassemble to mold them back into the locked position.
2. After you take the headlamps out of the oven, keep a heat gun pointed at the area you are trying to loosen. Once you get once section loose, the rest should pull apart. I used a putty knife to get things started and just worked my way around.
Hope that helps.
Old 07-03-2012, 03:12 PM
JK-47Man's Avatar
Great write up on the install!
I did this to my black JK and am really digging the look!
Quick Reply: Morimoto D2S HID Projector Retrofit
