Multiple cameras?
Instead of just one camera, like a backup camera, why not have lots of cameras to see what's happening all over?
I can have multiple cameras - front, sides, back - and they all pipe through a four way switch and when the mygig power button is pressed 2x (lockpick) to bring up what would normally be the rear view cam, I can control which camera I want to look at with my switch.
I would imagine that you would be limited only by the switch's number of positions. Of course, the switch would have to control the power supply as well, right? I mean, all the cameras couldn't be powered all the time.
If I found someone really smart I could ask them to somehow combine input from a few cameras onto one screen... and map each camera to a specific part of the screen... and then I could have that infinity-like system that shows a virtual top-down view of the car... but for my jeep. Was that Infinity that did that?
Anyhow, first I have to get the damned mygig working. My new Ruby has 70 miles on it and no navigation.
Well, I want to do it - the switched multiple cameras at least...
Do you think the other thing is possible? Really? I imagine it to be rather expensive, but how cool would it be to cruise confidently over/past obstacles that are only mm's away?
My plan is to put ccd's at each wheel well pointed down, then mux them through a hardware video box (not sure which one yet). The ccd's will be basic rear-view cameras, and should be able to sopt the wheels and diffs.
The mux will put all 4 images on the screen. Would be cool to be able to toggle front/back/all/reverse. Have to figure out the software for that.
Whenever I get to it, I'll post the write-up (assuming someone doesn't beat me to it!).
Right now, the most expensive part is the lock-pik to allow video while driving. Wish I could find a way around that.
I know you could trick the 6 spd into thinking it was parked if you pulled up on the e-brake just a notch or two. Not enough to engage the brakes, but enough for the system to think that the e-brake is on. That may have been changed with an update though.
