My new JVC Unit...
Old Oct 4, 2009 | 03:59 PM
dirtyjkwrangler's Avatar
Lookin good! I'm in Smithtown - I'll keep an eye out for you on the road.
Originally Posted by bubbad323
..if the photos are too small, they are posted in my gallery here on the forum
Dumb question - how do I get to your gallery from the forum??
Old Oct 5, 2009 | 04:09 AM
bubbad323's Avatar
Thanks brother! I cruise through smithtown every once in a while. As for the pics, I think you have to be registered in the myproject JK area of this site. Once you are, you can look at the member galleries and search by name. Look under "b" for mine and you will be able to see larger pics.
Old Oct 8, 2009 | 05:44 PM
bluejksahara's Avatar
Thanks for the info, Finally got mine in had to remove the bracket. I am having a issue with the face dragging the bottom of the panel. Did you have this problem and if so how did you remedy it? thanks
Old Oct 8, 2009 | 06:50 PM
bubbad323's Avatar
yeah, I had the same problem! Are you trying to have the unit sit flush? If so, you might want to adjust the side brackets and bring it forward a little, that's what helped me out. I really want it to sit flush when installed but I havent had the time to really see what is the culprit with the rubbing so Im leaving it as is for now. Just play around with the depth and you should be okay.
Old Oct 9, 2009 | 01:21 AM
yes it is flush, I will try to move it out some and see what happens. thanks again
Old Oct 12, 2009 | 02:55 PM
moved it out and it is worse wont open at all.
Old Oct 12, 2009 | 03:49 PM
Lontammi's Avatar
Looks nice awesome Job!!
Old Oct 14, 2009 | 01:26 PM
bubbad323's Avatar
Not sure what the problem is. Youll have to try and figure out where the rub is coming from and do some trimming.
Old Oct 18, 2009 | 06:36 PM
finally got it working but it sets out a bit more than i wanted, I will have to live with it for know. Thanks for your help
