MyGIG DVD Playback in Drive
The question of the day is "How can I play DVDs on a MyGIG unit while driving without having to purchase additional expensive components (ex: lockpick)?"
I did a search on this (and other) forums and found similar posts...you can't. Hopefully some genius has figured this out by now. So, how about it? Is there a cheap and easy override to allow DVD playback while the vehicle is in motion? My wife's Jeep Grand Cherokee has a MyGIG with Nav.
Unfortunatly there is NOT. Until somebody finds a way to alter the computer on the JK then it won't happen. I have been searching and searching myself since I got my jeep. But unless you buy the lockpick which seems to be the way then I don't know of any other way to do it. Give it time though I am sure somebody some day will figure it out
But I want my DVDs now! I read on a 300 website that someone was working on a software hack but so far no luck. The Lockpick seems pretty cool and has a lot of features but sure seems expensive for the little use I'd give it.
I have been keeping my eye open for a hard drive from a busted mygig. I work in the technology department at my local branch of A&M part time and there are some really smart people around me. So I was thinking since the mygig uses a form of Linux called qnx it may be hackable. There is a guy on those 300 forums who claimed a hack using software only, but he didn't offer anything to back it up. I don't know if the instructions to cancel playback are on the hard drive or cooked into the firmware? It would take someone a lot sharper than me to figure it out.
I do this in my wife's Dodge Grand Caravan with the MyGig system and it works GREAT!!! It should be the exact same software in the Jeep...let me know if it works for you.
All you have to do is simply start playing the DVD while in park. Before you shift into gear push the audio button on the side leave this menu up shift into gear and then press audio again...You should now be in gear and watching the movie that is playing in the DVD.
You can watch videos going down the road all day long!!
So if you upgrade the software, it won't work anymore.
Andrew
