mygig software
Old Jan 11, 2009 | 01:06 PM
dahammer's Avatar
Default mygig software
what are the pros and cons of using the 8.4 software on a mygig non nav(ren) to enable video in motion and opposed to using a lockpick, allgig.... thanks for any input
Old Jan 11, 2009 | 01:56 PM
jmat1980's Avatar
To get video in motin on the non nav with the software downgrade you must play the video while in park, then press audio (brings up audio menu) then place the Jeep in gear, then press show video. The video will then work in motion, but if you start messing with buttons to change scenes or something on the DVD, you will loose the video and have to stop and press the audio again...however, you can adjust the volume while m,oving and it will not affect anything
If youdont use it that often (like me) while in motion, it works just fine and is free as compared to $250 or so (??) for the lockpick...
Im not sure what else the lockpick gives you, I think there are some video in connections for a back up camera and it also allows you to use the uconnect and a few other features...
Old Jan 11, 2009 | 02:17 PM
dahammer's Avatar
are there any issues that could come up with downgrading the software? ive heard of possible harddrive corruptions. any thoughts on that?
Old Jan 12, 2009 | 10:31 AM
whpony96's Avatar
If you downgrade you will more than likely end up with a $1400.00 brick...
Old Jan 12, 2009 | 11:34 AM
JackMac4's Avatar
at the very least you need to crack it open and create a backup image of your hard drive before you downgrade, but I wouldn't recommend it.
Old Jan 12, 2009 | 12:40 PM
hscrugby's Avatar
The old software isn't that bad.
Heck install it, if you don't like it or it causes problems, just upgrade to the new version.
The non-nav's were a LOT less prone to HD corrupting, as they have a LOT few write cycles.
That being said, I'm the type that likes the newest software, so I wouldn't do it. But I'm also cheap so I wouldn't buy a lock pick either. :(
Good luck.
Old Jan 12, 2009 | 12:53 PM
dsy's Avatar
dsy
Depends what year your radio is. I have a 09 REN MyGig and tried flashing backwards and it would not let me.
