MyGig software update 2.045 Released today
I didn't realize that there would be a difference, I have an 08 Rubicon with the touch screen mygig head unit. I don't know what an rer and the others are. I had to use the 2 different part #'s to make it work.
I hope this helps as it too me 6-Hrs.
UPDATE 06/05/2010 TO CREATE ZIP FILE
RER UPDATE
PLACES UPDATE ZIP FILE ON TO DESKTOP......... RER_2045.ZIP
Official Shipping Release: Version 2.045 - Latest Software Update (RER)
http://mofv.com/MyGIG/WithNav/RER_2045.zipMyGIG Software Upgrade Version 2.045 (323 MB)
GN VERSION: 2064 UPDATE takes 1-1/2 hrs
The Gracenotes database identifies music tracks and provides song, artist and genre information for your music stored on your MyGIG hard drive or played from your MyGIG CD/DVD so that you see the actual track information instead of seeing tags like Disk 1 or Track 1. Updating your database will keep you up to date with database information from the latest songs.
The Gracenote updates are locale specific as opposed to radio specific as people in different parts of the world tend to listen to music from different performers so the database of songs is different within different global regions.
Official Release For US/Canada/Mexico: Version 2064 (GRACENOTE)
http://mofv.com/MyGIG/Gracenotes/GN_....zipGracenotes US, Canada, Mexico Download Version 2064 (870 MB)
LOOK at YOUR system set up menu and view SYSTEM INFORMATION and make notes of your current versions........, then,
PROCEDURE:
1) FIRST USE: YOUR BROWSER
I used FIREFOX AND GO TO http://mofv.com/MyGIG/
2) THEN CLIICK ON THE LATEST (RER) DOWNLOADS FOR NORTH AMERICA
3) A WINDOW WILL APPEAR AND SAVE FILE and a ZIP will be created onto the desk top. 30+ Minutes.
4) Gracenotes said 1-1/2-hrs.....
5) Burning CD's Name CD whatever you want to and the files copied and burned, I had
taken them "out of folders" . The RER worked FINE. DO NOT NAME CD version number.
6) Now for the Gragenotes. GN_2064_ME (There is a problem with this update) When you open up the zip, a folder is created with a folder GND8 and a file named gnupdate.
The PROBLEM is in the gnupdate file. What I did was simply, double click on the gnupdate folder and this is what appeared: version=ME-2064
I read others postings and I simply changed the ME- to US- and saved it and closed the window.
The corrected on should look like: version=US-2064
I burned the CD with the folder and revised gnupdate file AND IT WORKED...........
AGAIN, DO NOT NAME THE CD with version number
I named one cd Jeep RFR Update 06/10
Jeep GraceNotes Update 06/10
NOW, YOU ARE READY TO INSTALL IN YOUR JEEP.........
7) When INSTALLING IN JEEP, turn the key to 2nd position and
once you start, DO NOT TURN IT OFF ****
This is the ignition position (WILL NOT install if vehicle is running)
PUSH the Open CD, and the screen will automatically open.
insert CD and push the CD button to close the CD screen.
Software will them operate automatically. (It took mine UNDER a minute to begin)
(If it does not like your cd format, you will see a disc named DATA, but give it a minute or two to decide)
A LONG sequence of software installations will occur and they DO SHOW A PROGRESS BAR, and then a HEAD software update will change those settings too.
WHEN FINISHED, THE Screen will state finished by saying:
(I.E.) Software version #2064 to Software version 2064
IT DOES NOT SAY DONE or FINISHED *******
IF THEY ARE THE SAME,
THEN CHOOSE NO AND THE RADIO WILL REBOOT.
8) NOW FOR THE GRACENOTES:
MAKE SURE YOU CHANGED THAT ONE FILE TO READ version=US-2064
or your CD WILL NOT WORK.
IF A CD DOES NOT WORK IT APPEARS UP AS A DISC NAMED DATA and nothing happens.
What I do, was followed procedure#7 ABOVE and the software update window appeared and a display stated that this update would take 30-minutes.
When it finished, I REMOVED THE CD by using the CD Open/Close button.
9) AFTER ALL WAS DONE, I went to the menu button on Mygig head and pushed system set up and then found my system information and it had updated the RER and Gracenotes to the NEW version AND I found the screen DISPLAY format had changed from:
OLD SCREEN Format
GO TO: http://mofv.com/mygig/
System Set Up Menu, then choose System Informtaion and this appeared:
SOFTWARE
Applications DataBase Greenotes
9.668 RS9-N2080751 881
UPDATED 06/21/2009
RER 1.220 GN1287
HARDWARE
Serial Number System
SDS131574 681600635
NEW Screen Format
SOFTWARE
Application: 2045 Gracenotes: 2064
Database: RS9 N 207 0751 SDS: 170901
HARDWARE
Serial Number: T00BE071851317
System: 6816 006 3.5
RER UPDATE
PROCEDURE:
OLD SCREEN Format
SOFTWARE
UPDATED 06/21/2009
RER 1.220 GN1287
HARDWARE
SDS131574 681600635
NEW Screen Format
SOFTWARE
HARDWARE
Just purchased a new Unlimited Rubicon yesterday with MyGig RER and had a couple questions on system software and updates. When I put the 2.045 DVD into the drive, it asks if I want to upgrade from 2.107 to 2.045. It seems intuitive the RER in my Rubicon has a later rev of the software and I should *not* install anything. Gracenotes is version 2.057 btw but I really don't see any reason to upgrade since everything on the hard drive will be fully tagged .MP3 files.
Anyone else with this same version (2.107)?
Should I install 2.045? (I am guessing NO!)
Does Gracenotes provide any value for fully tagged MP3's or am I missing something that it provides beyond song/band/album/genre/year/etc... information?
Thanks!
Thanks!
