Mysterious unused wire loom and connecter found under hood
Found these wires unused under the hood, one on each side.
it has 3 wires, black white white/yellow i tested all the pins with a test lamp, only the ground was connected. also tried switching on all the lights with rear fogs and retested.... no current. i have an export model Euro spec 08 X with rear fogs only. i am suspecting: -that it could be for the fog lamps but it has no power because it is missing some sort of fuse -it is used for the U.S specs headlights, and it was left disconnected. What do you think it is for? check yours if you have it, this is kinda fun:D http://img8.imageshack.us/img8/1089/photo171uv.jpg http://img29.imageshack.us/img29/812/photo169y.jpg http://img9.imageshack.us/img9/3516/photo170a.jpg |
Based on the location I think that is the plug for remote start.
Here's all I could find hope it helps
CAV CIRCUIT FUNCTION 1 L13 18WT/YL HEADLAMP ADJUST SIGNAL 2 L135 18WT HEADLAMP LEVEL CONTROL SIGNAL 3 Z904 18BK GROUND |
Originally Posted by renegadelt1
(Post 1391189)
CAV CIRCUIT FUNCTION 1 L13 18WT/YL HEADLAMP ADJUST SIGNAL 2 L135 18WT HEADLAMP LEVEL CONTROL SIGNAL 3 Z904 18BK GROUND hmmm. Wow i guess this is it, My JK does not have headlamp level control. so it must have been left unused from the factory. Nice shot...May i ask where were you able to get that info? thanks. |
Check you PM's I sent you some info:thumbsup:
renegadeLT1 is where the Guru of Guru's goes to get answers.
I wish I had that harness in my JK. I would love to hook up the headlight level adjustment system!
Originally Posted by whpony96
(Post 1392633)
