Mysterious unused wire loom and connecter found under hood
Found these wires unused under the hood, one on each side.
it has 3 wires,
black
white
white/yellow
i tested all the pins with a test lamp, only the ground was connected. also tried switching on all the lights with rear fogs and retested.... no current.
i have an export model Euro spec 08 X with rear fogs only.
i am suspecting:
-that it could be for the fog lamps but it has no power because it is missing some sort of fuse
-it is used for the U.S specs headlights, and it was left disconnected.
What do you think it is for? check yours if you have it, this is kinda fun
it has 3 wires,
black
white
white/yellow
i am suspecting:
hmmm. Wow i guess this is it, My JK does not have headlamp level control. so it must have been left unused from the factory.
Nice shot...May i ask where were you able to get that info? thanks.
