Need electrical help! Not TIPM
I have some electrical issues 2011 jk i thought were being caused by a failed TIPM but after replacing it the exact issues still remain and i am at a loss.
Issues are: Headlight on but cannot turn them off Wipers stuck on but washer pump not working Nothing on my steering wheel works except cruise No turn signals Traction control light is the only warning light on No codes or other lights Any ideas? Im all out of them. |
Headlights, wipers and turn signals sound like the multifunction switch is bad. The no buttons on the steering wheel and trction control light sound like clockspring. The cruise working with the traction control light on is just plain weird. When my clockspring broke and the tc light was on, cruise would not even come on.
Did your steering column get wet or something? |
Thanks for the insight. Just found out the clockspring is under recall so I booked it in for that and will wait to see if that fixes anything. As far as getting wet I get caught in the rain here in florida quite often with my top down and doors off. Not sure what the multifunction switch is but will do some research into it. Just cant see it being multiple issues due to everything happening at the exact same moment?
Originally Posted by Michael Paul
(Post 4343573)
Clock spring needs replacing.
