Need help with Horn wire
Old Nov 26, 2009 | 10:27 PM
Dre64's Avatar
Default Need help with Horn wire
Alright, I know some of you have shop manuals with wiring diagrams. Basically I am installing an aftermarket keyless entry, and would like to know which wire is the one going from the steering wheel horn switch to the horn (or computer, or whatever), I need the color of the wire... the diagram I have said the green/violet wire, but that has proven unsuccessful, such that with the wire cut completely the horn still works. Anyway, any help would be appreciated. Thanks.
Old Nov 28, 2009 | 11:01 AM
Dre64's Avatar
no? ...bump.
Old Nov 28, 2009 | 09:50 PM
James76's Avatar
the horn wire requires a long and strong ground pulse to activate. It is actually a multiplexed pulsed wire at rest and straight ground activates the bcm to trigger the horn relay. i havent had much luck getting it to work. that sounds right its either green violet or violet green...
Old Nov 29, 2009 | 05:37 PM
Dre64's Avatar
k, thanks... I guess I'll try finding the relay and just hooking it into there...
Old Nov 29, 2009 | 05:39 PM
James76's Avatar
i havent spent any time looking for it, let us all know if you do find a good solution for it. If worse came to worse i guess you could just add your own horn circuit
