Need help. Interior lights won't turn off
Old May 27, 2012 | 04:45 PM
jim hensley's Avatar
Default Need help. Interior lights won't turn off
Both interior lights won't turn off. Tried all doors including the tailgate a dozen times. Have to disconnecct tje battery so it doesn't drain down. Any ideas. We installed a new set of Bushwacker fender flares yesterday and no issues yesterday and last night. Just left this morning and they came on and would not turn off. Need help somi don't have to make a trip into the dealer.
Old May 27, 2012 | 04:53 PM
Biggy's Avatar
Were you in the cargo area of the jeep. The rear light is a push on light as well. Try pushing it in and out.
Old May 27, 2012 | 04:54 PM
JWKIB's Avatar
did you check the dimmer switch for the dash lights. if its turned all the way up it will turn on the dome lights
ronjenx's Avatar
Is the instrument cluster brightness switch on the left stalk rotated all the way forward? That turns on the dome lights.
Old May 27, 2012 | 05:05 PM
Great thoughts. I have no checked the dimmer switch and we were testing the lights. Need to wait until this thunderstorm passes to test. Thank you all.
