need KC slim light help
Old Mar 11, 2009 | 03:06 PM
cenhockey55's Avatar
Default need KC slim light help
i took my kc slim light a part to replace the bulb and the 4 metal rods came out and i cant figure out how to put them back in to keep the light in place i dont no if theres a diagram or if someone that has replaced there bulb could take a picture of were the rods go.
Old Mar 11, 2009 | 03:09 PM
Captain Hook's Avatar
4 metal rods?
My KC's only have 1 'rod' and it kinda acts like a spring and clips into a retainer to keep the bulb in place.
Old Mar 11, 2009 | 03:53 PM
no thats the thing that keeps the bulb in im talking about the rods that keep bulb housing tight against the bezel
Old Mar 11, 2009 | 05:25 PM
roketman's Avatar
Take the back off of the other and look at it. I took one apart last week and they are a pita to put back together. Make sure that you line up the lens so that it will be in the right position in relation to the screw hole. I took a set that I've had for 7-8 years and rebuilt them. KCs website has all the gaskets, wiring, bulbs and even the bezels to make them new again.
Old Mar 11, 2009 | 06:56 PM
Rock Sniper's Avatar
I had the exact same shit happen to me! Four metal rods rolling down my hood. I stuffed 'em back in the best I could but, I'm sure i didn't do it right . I can't get the lens assembly to fit tight like it was. ???? Kind of a stupid design.
Old Mar 11, 2009 | 07:26 PM
ya its a horrible design im tryin to rig somthing up that i keeps them from coming out
Old Mar 11, 2009 | 08:48 PM
roketman's Avatar
The Slim Lights have 4 small spring-like tensioners in them.
Old Mar 12, 2009 | 06:57 PM
DGOJK's Avatar
Did you get it back together? It is pretty simple and holds the reflector in well if they are in correct. The ends slip under a groove in the outer housing in various locations and kind of form a square against the reflector.
You do need to rotate it so the one screw hole lines up for housing.
Old Mar 13, 2009 | 10:14 AM
ill try that and let you know how it works out thanks
