Need pictures of Susquehanna harness install please
I am installing the harness and new Cibie lights tom Daniel Stern.
Do you have pictures of how and where you installed the harness??? I just want to be sure before I short out the whole damn Jeep.
It's impossible to short it out. I don't have pictures, but here's how. There's an H13 male connector with THREE wires on it. There's JUST ONE. Unplug your passenger side headlight and plug that H13 male connector into the female passenger headlight plug from the factory harness. Mount your relays. I chose the stud coming out of the firewall right behind the battery. I simply got an appripriate size nut, slif the relay bracket on it and tightened it down. Route the wires towards the headlights. THe headlight plugs are the ONLY two plugs on the harness that are the same. Removing the grill makes routing the driver side harness possible. When you're done there, just plug the headlights in, connect the ground and hot to the battery and you're done. Too bad you're not in Georgia. You could ride over and I'd do it for you. There's really nothing to it.
