Need plugs for fogs.
Old Apr 13, 2011 | 06:52 AM
RubiconEurope's Avatar
Default Need plugs for fogs.
I have an 2011 JK but I cut off the plugs and spliced in and crimped the HID ballast wires to have h16/5202 HID kit in my JK, now Im replacing fogs and putting halogens back on...I want to stay OEM...can I put h10? where can I find 2011 fog harness again..and 2011 lamps..or can I use previous years H10? I dont mind wiring harness just curious if itll be plug and play..
Old Apr 13, 2011 | 07:04 AM
Policejeep's Avatar
Just curious, why are you going oem when you already have the hid installed.
Old Apr 13, 2011 | 07:05 AM
finnd1's Avatar
it 'should' be an h10 bulb. Just do a google search on "h10 harness" and you can find what you need to splice the correct plug back in.
Old Apr 13, 2011 | 08:12 AM
Because I had ballasts go out when fording in water...Im taking off all HID's..
Old Apr 13, 2011 | 07:04 PM
86CJ-07RUBI's Avatar
The H10 connectors, pigtails, and extension plugs are all on this page.
I ordered a set last week, fast shipping.
hXXp://autolumination.com/connectors.htm
Old Apr 13, 2011 | 10:22 PM
did they work on your 2010 -2011 fogs? If I put in a h10 bulb with those plugs, into a 2007 fog light would they work fine?
