need some help on wiring harness
Old Nov 5, 2010 | 04:47 PM
Dwikto's Avatar
Default need some help on wiring harness
i ripped my harness off on the trail and have 4 wires that i have no idea how to hook to the new 4way plug, the colors dont match the function, could someone please give me a stock wire color to trailer wire color.
stock: trailer:
black to ?
white w/green ?
white w/yellow ?
white w/red ?
standard trailer wiring:
brown green yellow and white
function:
stop, lft turn, rt turn, common(grnd)
Old Nov 5, 2010 | 08:22 PM
Dwikto's Avatar
help please i need to get this done even a picture of the 4 way plug showing the wires in relation to the plug position
Old Nov 6, 2010 | 01:19 PM
Dwikto's Avatar
please a shot of your 4 way plug
Old Nov 6, 2010 | 01:26 PM
genesbro's Avatar
If you have a volt meter you can use it to identify which wire to hook up to the colors on your connector. I don't have the factory tow so I can't help you out tht way.
4 way flat molded connectors allow basic hookup for three lighting functions; right turn signal / stop light (green), left turn signal / stop light (yellow), taillight / license / side marker (brown) and a ground (white).
Old Nov 6, 2010 | 05:53 PM
Dwikto's Avatar
yeah that is the problem i am getting conflicting signals i have no signal coming out for lft turn therefore i need to know what wire is bad both rt turn and stop seem to coincide with the white wire with green stripe. if i new the position of the wire in relation to the plug on the stock set up i could figure the rest out. for example:
the plug has one rubber sleeved female connection then three open male connections. i just need to know what colors line up
female 1: ? stock color
male 2: ? stock color
male 3: ? stock color
Old Nov 6, 2010 | 09:09 PM
genesbro's Avatar
If you can't use a meter and the information that I posted earlier to get those wires together then I would suggest that you take it to a profesional.
Old Nov 7, 2010 | 07:20 AM
Dwikto's Avatar
thanks for the suggestion, however if i had a picture of the stock 4way i could diagnose the problem, i do have a meter and i know how to use it. i built my trailer and i know how to hook up the wiring from scratch the problem is when i was rock crawling i ripped the stock connector off and lost it. so now i have four wires and need to know the sequence.
Old Nov 7, 2010 | 07:51 PM
Dwikto's Avatar
wow 154 views and no one had a stock wiring harness to take a picture of oh well i did it the long way around.
I pulled out the wiring harness and used my meter to find a short in the line repaired it and away we go.
should anyone need the info
stock trailer
black common white
white/red park brown
white/green LFT/brake yellow
white/yellow RT/brake green
if you ever have to do what i did do not match up the colors to a standard harness they are not the same.
d
Old Nov 8, 2010 | 07:16 AM
TheePsycho's Avatar
Here is the pin out for the 7-way, these should be common wires for some of them.
I have the 4 way I can look at when I get home.
2x White Wires = Ground
Red = 12 volt
Blue = Electric Brakes
White / Yellow = STOP/TURN RIGHT
White / Brownish Gry = BACKUP LIGHT
White / Light Green = PARKING LAMP
White / Turquoise = STOP/TURN LEFT
