New LED Dome Lights Blinking
Old Dec 25, 2013 | 10:39 AM
matprovo's Avatar
I just popped in new led dome lights that I got from Northridge and they continuously blink. Both sets blink so I don't think it's a bad bulb. Am I missing something here? Should just pop out the old and put the LEDs in correct? Any help is appreciated.
Old Dec 25, 2013 | 05:42 PM
matprovo's Avatar
Someone has to have an idea about this???
Old Dec 25, 2013 | 08:26 PM
Jersey_Devil's Avatar
Try flipping the bulbs around. Usually leds don't work at all if u put them in backwards but it's worth a try. If not I'd get my money back and get them off eBay where u can buy 20 bulbs for like 5 bucks. Just search led replacement bulbs and they all come up
Sent from my obama monitoring device
Old Dec 25, 2013 | 08:55 PM
matprovo's Avatar
Try flipping the bulbs around. Usually leds don't work at all if u put them in backwards but it's worth a try. If not I'd get my money back and get them off eBay where u can buy 20 bulbs for like 5 bucks. Just search led replacement bulbs and they all come up Sent from my obama monitoring device
Thanks. I'll give it a shot and see. If not I'll give Northridge a call tomorrow.
Old Dec 25, 2013 | 10:03 PM
Quite welcome! Cuz I've never heard of domes flickering like that. I got other EXTERIOR bulbs that needed resistors so they didn't flicker but def not my domes
Old Dec 26, 2013 | 11:02 AM
matprovo's Avatar
That didn't work. It's really weird. When you manually turn lights on they blink. But when activate lights by either opening door or unlocking with remote they stay on with out blinking.
Old Dec 26, 2013 | 11:21 AM
Croce's Avatar
I have a similiar issue with my LED dome lights when i try to manually turn them on, they dont blink but are extremely dim and only work when opening the door or unlocking with a remote. Never had this issue with the stock dome lights, seems to be something with the LEDs
Old Dec 27, 2013 | 04:25 PM
VETTETHRET's Avatar
Ordered the same ones from northridge for my 13. My map lights stay on which Dave said they would (I used electrical tape and taped them). My rear dome light burned out after two days, not happy about it!
Old Dec 27, 2013 | 07:30 PM
PAShadowJK11's Avatar
It probably has something to do with the dimmer on the circuit.. LEDs need to be dimmed differently than regular bulbs what your seeing is prob a result of the dimmer not having enough load kind of how you can't do a direct swap on turn signals because they require the load to trigger the flash.., throw in a resistor and your should be fine.
Old Dec 28, 2013 | 10:40 AM
matprovo's Avatar
The map light stays on? That's crap. I'll call Northridge next week after the holidays and see what's going on.
