NOT the stock HU......Help
I'm not exactly sure if i'm understanding your posts correctly. Your English seems a bit broken but I think you're saying I should just use the fade to put more sound to the rear.... This only takes sound from the front. If I fade completley to the rear and then turn the volume to the max, it is still barely at a normal listening level. Also no bass, and flat muffled tones.
Anyone else? Theres got to be someone around here that knows the fix.
One more thing. Let us say that since this a chrysler MyGig, that is why the soundbar power is still being reduced. My question would be: Why were the rear speakers not 'muffled' in the van it came out of?
That's just it... I have. Not only this forum, but others as well. No one has an answer. It can't be that difficult to figure out for someone who knows how these systems work.
Originally Posted by Back_Again
There is not RCA plugs in the back of the MyGig head unit. It uses the factory harness. Plug and play. Are you suggesting I pull the wires out of the harness?
