Nubie question on a dome light issue.
Old Jun 26, 2013 | 05:02 AM
WebWolf's Avatar
Default Nubie question on a dome light issue.
I have had jeeps for many years, still my favorite was my '79 CJ7 Golden Eagle with the 304 V8. I just picked up a new '13 Rubicon Unlimited and after owning it a couple days, the dome light stays on when you start the jeep. I turned off the dome light on the blinker knob and it stays off when you open the door as it should but if you start the Jeep, it comes on and stays on until I shut the truck off and then it stays on for about 5 minutes until the battery saving timeout trips. I took it back to the dealer, they said they can look at it if I leave it a couple days. I threw the BS flag on them and I am hoping someone could point me in the right direction. I have unplugged the front doors, sprayed the connectors and reseated them. BTW, the doors all say they are closed since my dash does not show any door ajar icon.
I am guessing that the door switch is in the latch and not a plunger like normal cars
Old Jun 26, 2013 | 05:10 AM
Rednroll's Avatar
LOL!!! Been there done that when I 1st got my JKU. Pretty much did everything you mentioned when it happened to me and was banging my head against the wall. Your problem is that you probably accidentally bumped the rear dome light lens. That lens is an on/off switch and is currently in the ON position. Push in the lens until you hear the click, to put it back into the OFF position and the dome lights will start going off when you close the door.
I can't believe a dealer couldn't suggest that to you within a 1 minute conversation.
Old Jun 26, 2013 | 05:16 AM
WebWolf's Avatar
Thanks for that tip Rednroll but tried it, I can turn the lights on and off with that switch along with the ones in front when it times out. I appreciate the quick response
