O2 sensor connector replacement
Old Dec 31, 2021 | 03:57 PM
JDaPP's Avatar
Default O2 sensor connector replacement
I have a 2012 JKUR. Keep getting a 0058 code for bank 2 sensor, which I have replaced several times. Wire on engine side of the sensor harness was broken and I spliced which worked for awhile but broken wire was too close to sensor so I would like to remove the pin and splice in New wire with new pin.
I have looked around but I am having trouble figuring out what style of pin I need or if there is a repair kit, so if anyone can steer me in the right direction I would appreciate it. It is a 4 pin connector if that helps at all. Thanks in advance.
Old Jan 4, 2022 | 09:59 AM
Faalin's Avatar
Mopar Connection Repair Kit
Here are the two repair kits i found for the O2 sensor, you could probably got to your closest Jeep dealer and ask to look at it to see if the pins come with it or its just the plastic out housing.
