Off road lights switch
Old Aug 29, 2012 | 02:50 AM
Lane87's Avatar
Default Off road lights switch
I had a daystar switch hooked up to my windshield mounted KC hilites. I've barely used it and the switch is already broken. My question is this- Is there another brand of switch that would be more sturdy and also fit in the same hole I cut for the daystar switch. I would also prefer if it had an LED, the light in the Daystar switch gets so hot! Thanks in advance for your comments!!
Old Aug 29, 2012 | 05:43 PM
Tizzyusmc's Avatar
autozone has a variety of switches you can get that will be the same size as the daystar- also you can prevent the light from getting hot by adding a fuze at the switch less than 15 amp depending on what hot wire you used to run to the switch. make sense??
Old Aug 29, 2012 | 07:12 PM
Sommer13's Avatar
Painless Wiring has a setup for the whole panel if you don't wanna worry about looking for a swith that will fill in the hole for the daystar one, and the swithces are built in.
Old Aug 30, 2012 | 10:27 AM
Bull's Avatar
check out OTRATTW.com. Same switch body size, led lights, custom etching. Very nice.
Old Aug 31, 2012 | 05:28 PM
bobberdown's Avatar
The ottoraw switches are badazz
