offroad lighting connection
Old Oct 12, 2012 | 10:52 AM
Pawel's Avatar
Default offroad lighting connection
I recieved a set of offroad lights for my jk to mount on either side of the windshiled by the mirrors. I'd like to know what the safest way to connect them would be. The lights came with a their own wiring and a fuse. Should i buy a relay, run the relay to the battery and then the lights to the relay? Or is there a way where i would be able to connect some sort of box that would allow me to connect more lights at another time if needed.
Thanks!
Old Oct 12, 2012 | 12:21 PM
notsoricer's Avatar
Yea to everything. If its the only set of lights you plan on adding then just buy a relay and connect to battery, accessory fuse, ground, and lights. If you plan on having an arsenal of lights then I would start looking at a box to clean things up a bit. If money's not a factor then check out spods.
Old Oct 13, 2012 | 07:02 PM
Pawel's Avatar
Thanks for the answer! do you know of any other companies that make boxes? Something a bit cheaper? haha
