Oil Change Light
Old Oct 20, 2008 | 06:07 AM
moho's Avatar
Default Oil Change Light
Can anybody remember the sequence for disableing the oil change light.
I change my own and cant remember the steps, or maybe I m just holding my tongue wrong.
Old Oct 20, 2008 | 06:13 AM
Okie4WD's Avatar
Key on to acc...
pump gas pedal three times
Key off
remove key
open door
close door
return key to ignition
turn key.....
done.
Old Oct 20, 2008 | 06:19 AM
LifeTime's Avatar
Turn key to on. (Do not press clutch or brake.)
Wait till chimes stop.
Press gas pedal to the floor 3 times. (Be sure to make engine reving noises with mouth )
Turn key to off.
Next time you start the JK, light should be gone.
Old Oct 20, 2008 | 06:40 AM
moho's Avatar
Thanks,,, I forgot to make the varrooooom noise, I was making a clackety cluck type. I was using the brake pedal.
Old Oct 20, 2008 | 01:11 PM
rtp208's Avatar
key in, with one hand pat your head with the other rub your belly. I cant do this so I stopped changing the oil.....
