Optima Yellow Top size 34
Old 04-20-2014, 10:17 AM
DSmith1178's Avatar
Default Optima Yellow Top size 34
Im getting ready to install a winch on my 12 JKUR. I have a size 34 yellow top optima battery from an older vehicle Iaying around that Id like to use. I tried to install it and it fits fine but the stock cables are about 3 inches too short due the terminals being on the other side of the battery. Has anyone been able to get a group 34 battery to work in a 12,13,14 JK? Thanks
Old 04-20-2014, 11:29 AM
DSmith1178's Avatar
I guess I should ask if theres any slack or clips on the stock cables that can be let out to give me and extra couple inches to be able to reach the optimas terminals.
Old 04-20-2014, 11:32 AM
Big Buger's Avatar
I'm not sure if it would work or not but the optima battery can be put on its side.
Old 04-20-2014, 11:35 AM
DSmith1178's Avatar
Techinically it can but It would be next to impossible to strap down. Still wouldnt be enough slack to get cables to reach
Old 04-20-2014, 12:02 PM
DSmith1178's Avatar
Found the answer!!!! Here is a link for all interested. It can be done with the cutting of a few clips.
http://www.wanderingtrail.com/Mods/2...ma/optima.html
Old 04-20-2014, 01:59 PM
Big Buger's Avatar
Good job the internet makes life so easy.
Old 04-20-2014, 02:45 PM
Collyn's Avatar
Gonna say...I have a group 24 Stinger 1800 in the engine compartment and it fit. Bolted down fine. The cables barely reach, but did. Like above, just need to clip a couple plastic wiring harness retainers.
FWIW, you can get a decent sized AGM battery under each front seat. I have a pair of Stingers under the front seats and since they are AGM style they are non spill-able and the seat brackets hold them firmly in place. The battery isolator and fusing is under the hood on the firewall next to factory location.
Quick Reply: Optima Yellow Top size 34
