PAC RP4-CH11 No Sound from JVC Stereo
Old Jun 22, 2024 | 12:17 PM
MKIVBB's Avatar
Exclamation PAC RP4-CH11 No Sound from JVC Stereo
Just installed a new JVC radio with the PAC RP4-CH11, followed the instructions correctly by wiring the front speaker outputs from the JVC to the rear speaker inputs of the PAC RP4-CH11. Stereo itself lights up and turns on like it should, but I'm getting no sound. All of my wiring connections are good (I've installed many car stereos over the years). Steering wheel controls work fine. Everything looks perfect, but no sound. Any ideas?
Old Jun 23, 2024 | 10:57 AM
MKIVBB's Avatar
SOLVED: For anyone who's interested, I figured out my problem. I didn't realize that I needed to hook up the blue/white remote amp turn on wire from the PAC harness. I'm using the factory amp, so I assumed that it would turn itself on with signal from the speaker wires running to it. The PAC instructions did not say that the blue/white wire needed to be hooked up to a switched power wire to turn on the factory amp. I just spliced it in with the red accessory power wire, so all is good now.
Old Aug 28, 2024 | 09:41 PM
shokjeep's Avatar
I was having this exact issue and you helped solve it man! Couldn’t find anything anywhere else. 👍🏻
Old Aug 29, 2024 | 01:40 PM
MKIVBB's Avatar
Glad I was able to help!
