Parking light modification - wiring help needed
Old Dec 24, 2016 | 08:48 AM
Rmerkushen's Avatar
Default Parking light modification - wiring help needed
Need help from the group.. purchased recon led front parking/turn signals. Installations was a breeze, mostly plug n play with the exception for resistor install to eliminate hyper blinking. I like the look, but the LEDs are not bright enough and I am concerned that oncoming traffic won't see the blinker when turning.
Its actually worse at night as the differed between parking light on and blinking light is very subtle, which strikes me as a safety issue. What I would like to try is turning off parking light altogether when turn signal is turned on. I started to research this but still haven't come across anything that would help. I understand this may be done via a 5 pin relay or combination of relays. Anyone has done this yet, if so please share your wiring diagram.
ideally, I would want to eliminate the resistor as well and get relay that has resister built in so I can simplify wiring process.
Btw it's a 2015 jku..
Thanks a lot!
