Please help me - serious electrical problem
Old Jul 11, 2011 | 01:44 PM
centerfieldr162's Avatar
Default Please help me - serious electrical problem
So I was just outside re-wiring my rock lights with 10 gauge wire instead of the 12 gauge that I had originally wired it with. I flipped the switch to turn my rock lights on and my dome light inside the Jeep went off and I heard my subwoofers make a noise and my rock lights didn't turn on. I switched a fuse in my rock lights and they still didn't work. I went to go turn my Jeep on and it won't even turn over, all it does it click and the windshield wipers started going nuts. What the hell do I do?!?! I'm freaking out
Old Jul 11, 2011 | 01:45 PM
azrwilkinson's Avatar
Sounds as if you have a short somewhere....and possibly a blown fuse. Check under the hood at your fuses and GOOD LUCK!
Old Jul 11, 2011 | 01:46 PM
Which fuses do I check?? All the ones in my fuse box??
Old Jul 11, 2011 | 01:47 PM
pettym's Avatar
definnatly sounds like a short. Make sure no bare wire is exposed or crossed anywhere. Pull the rock lights off totally, try to fire up the jeep. If it works, start wiring them scratch.
Old Jul 11, 2011 | 02:06 PM
Coley's Avatar
If your wipers are turning on, that's a sign the computer has gone into limp mode. Disconnect the battery and aftermarket wiring, wait 30 minutes and reconnect just the battery, see if it starts.
Old Jul 11, 2011 | 02:08 PM
When the key is in the ignition and the battery is on, if I flip the swich and turn my rock lights on, my radio cuts off and the interior lights dim
Old Jul 11, 2011 | 02:17 PM
pettym's Avatar
did you take out the aftermarket wiring?
Old Jul 11, 2011 | 02:33 PM
Aftermarket wiring for what?
Old Jul 11, 2011 | 02:42 PM
Also, beside my button for caution lights, there is an illuminated thing that says my passenger air bag is off
Old Jul 11, 2011 | 03:47 PM
Anybody have anything to say?? Please I'm desperate
