Plug for factory tow harness?
After upgrading my rear bumper (ACE Engineering Pro-Series) on my 2010 JKUR, I removed the factory 8-pin (or was it 7? I didn't count) socket and bracket as there wasn't a good place to mount it. I'd like to plug the remaining connector so it doesn't get water/mud in it during off road excursions. Anyone know if there's a factory water tight plug for it?
Sent from my iPhone using Tapatalk |
Bump.
well its not exactly what you are looking for, but if you have a roll of good heavy duty electrical or gorilla tape you can seal the head right up, just put on real solid layers, 2-3 should do the trick, not impossible to remove later, but wont just fall off anytime soon on its own :thumbsup: and you can stick up in the frame while you are down there to keep it from snaggin anything.
| All times are GMT -8. The time now is 06:18 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
