Plug for factory tow harness?
After upgrading my rear bumper (ACE Engineering Pro-Series) on my 2010 JKUR, I removed the factory 8-pin (or was it 7? I didn't count) socket and bracket as there wasn't a good place to mount it. I'd like to plug the remaining connector so it doesn't get water/mud in it during off road excursions. Anyone know if there's a factory water tight plug for it?
well its not exactly what you are looking for, but if you have a roll of good heavy duty electrical or gorilla tape you can seal the head right up, just put on real solid layers, 2-3 should do the trick, not impossible to remove later, but wont just fall off anytime soon on its own
and you can stick up in the frame while you are down there to keep it from snaggin anything.
