Plug wire
Ok found a meted plug wire from the JBA header heat I had good wires with boot covers but oviously need better plug wires or ones that can handel the heat better any help
Josh
Josh
Some good insulating wrap should do the trick for you. Not sure if you should wrap the wires or the headers, or both. Personally I'd wrap both, the headers for overall underhood heat and the wires just for some extra protection since they're so close.
