power outlet
I was wondering if there is another fuse for the power outlet on a 07? Both of them have no power and I checked the fuses in the electrical box under the hoor. I don't know if this is significant but i do have the jeep GPS unit that runs off the same circuit. Thanks for your help.
I also have an '07, and have this exact same problem. Not only did I check the 3 fuses listed in the photo, but I replaced them with new ones, as well, bit still have no power on the right side, unswitched power outlet. Is there anything else that can cause this problem? Possibly an inline fusible link, or similar?
Originally Posted by k0260
I'll have to check as well... was it loose or completely disconnected?
Hmmm....see? That doesn't give me a lot of faith that I'll find my problem there. I thought you may have meant that it had a melted wire there, or something similar, indicating that it had been overloaded. Mine quit working when I had a 350 watt power inverter plugged into it, and the inverter overloaded it, because the inverter itself was overloaded. Just about the same second that the over voltage alert on the inverter beeped, the outlet lost power. I assumed it was a fuse, but after 3 times pulling every fuse in the box, and even trying a known good one in each location, there's none blown. I'm assuming I either melted the socket itself, or burned a wire. Hopefully I'll find it soon, once you're used to having 2 outlets, you really miss one!
