Problem with fuse or switch
I just installed the rugged ridge 3 x 6" HID lighting through their harness to a daystar switch. And it works if the switch is ON when the ignition is turned on. But the switch is off or switched off, then the lights won't turn on.
Anyone know if this sounds like a bad relay or a bad switch?
I am dumbfounded whether it's how the wires are hooked up to the fuse or whatever.
Spliced into high beam wire so they turn off when low beam turned on. This works going off and on no problem, but if the daystar switch is turned off or the ignition is turned on while switch is off, the lights won't turn on.
