Problem with wiring/installation of KC light Bar
https://cimg4.ibsrv.net/gimg/www.jk-...dca5a5f14.jpeg This is where I mounted the relay. Maybe not good enough for a ground? Still not able to get power to switch. https://cimg9.ibsrv.net/gimg/www.jk-...07f5f3769.jpeg https://cimg0.ibsrv.net/gimg/www.jk-...81f7d8bbd.jpeg https://cimg1.ibsrv.net/gimg/www.jk-...685bb386c.jpeg Installing a new KC HiLiTES 20” light bar 335 and not able to get power to LED rocker switch or lights. Attached are photos, so I’m thinking that I have a grounding issue or switch leads are not correct? Any advice will be appreciated. Thanks in advance. |
No photos. |
I would not trust that ground. Those bolts are *not* intended to serve as grounds; they are solely meant to tighten/secure the factory termina/lug to the battery post.
Did you verify that ground with a voltmeter? I would ground to a known-good ground (e.g. the 10mm chassis ground studs that exist in several places behind the fenders). |
Thanks, I’ll check and try out one of those ground bolts you suggested. |
