Problem with woring
Last week, I installed my 2 fog lights on the windshield brackets, and the switch in the dash.
Today, i install the wiring (Delta Tech wiring for Wrangler JK) and I have to pass 2 wires located near the battery and going to the switch inside the dash.
Here is my question: Where do I pass the 2 wires? I don't see any hole!
What is a firewall? It's the piece of sheetmetal that's blocking you from passing the wires straight from the engine bay into the area behind the dash.
Here's one option to pass through the firewall.
That's where I ran mine, then I mounted the power switch right there above the speaker in that image. Makes a nice, clean install. Poke a coat hanger through it to clear out the sealer. Use a little RTV afterward to reseal the hole. There is a similar passthrough on the other side of the JK, BTW.
