programming computer
Old Jan 31, 2009 | 02:59 AM
BrianJK's Avatar
Default programming computer
Is there any software out there that can make your laptop do the same thing as the hypertech programmers?
Old Jan 31, 2009 | 04:16 PM
JackMac4's Avatar
Yes, there is, but it costs about $6000. It's the software that people like Hypertech use to make their units. It's basically an OBD/CAN communications software that allows you to do bidirectional read/write to the CAN system. I did some research into it and found all the things you need, but its pretty outrageously priced. They don't intend it for normal users. It's intended for shops to do in-depth programming/analysis or manufacturers.
There might be other/cheaper software out there, but I didn't find any when I was looking.
Old Jan 31, 2009 | 05:10 PM
tambil68's Avatar
AEV has their new pro cal (?) out. And you could check on the Aeroforce gauge as well, depending on your wants. Even if you have the bi-directional communication with the canbus, I would think (read I don't know) if you could really screw it up not understanding all of the relations and setting paramaters.
