question on sub install
Old May 28, 2007 | 01:15 PM
dahman45's Avatar
Default question on sub install
ive been searching and looking around and was trying to get a definitive answer, can u install a sub with the stock (no infiniti) headunit. i remeber seeing a post about some piece of equiptment that can take the bass signal out of the speakers to go to an amp. but couldnt find the post. i really want a sub but dont want to loose the stock looking headunit!!!
sorry for bringing it up again but i need a definite answer......
thanks!!!
Old May 28, 2007 | 01:16 PM
bodybrdng's Avatar
Yes you can. You need a low pass filter. I have one i can send you just pay shipping. use butt clamps and then rca to the amp then the subs.
Old May 28, 2007 | 01:21 PM
dahman45's Avatar
oh cool do u have a link to what it is?
Old May 28, 2007 | 01:33 PM
bodybrdng's Avatar
No when i had my sound system installed by sound soulutions they already had one. I think shipping is only like 5 bucks
I will post a pic of it later
Old May 28, 2007 | 01:45 PM
dahman45's Avatar
now i dont want crazy bass, i just want a little bass with my factory system. i was thinking about a self-powered sub, like a bazooka tube or the mtx thunderlink. im confused on those can u just wire them up to ur stock headunit? and if u can, how?
Old May 28, 2007 | 02:02 PM
bodybrdng's Avatar
you can but you need that low pass filter to cut out the high frequencies. it only filters.
Old May 29, 2007 | 09:29 AM
JackMac4's Avatar
You're basically looking for a hi-lo adapter...something to take your speaker level input and convert it to RCA, which you can then take to an amp/sub or bazooka tube via RCA.
As far as filtering, you can usually do that at the amp...if not, a low pass filter can be put in-line without issue.
They are easily obtained locally at any car stereo shop...and are commonly used for this type of installation.
Old May 29, 2007 | 01:41 PM
dahman45's Avatar
awesome thanks for the info!!!
Old May 30, 2007 | 04:53 AM
bodybrdng's Avatar
Thats what i was trying to explain. I am willing to give you the part. If you don't want it then it's going in the trash, I don't need it any more. If anybody wants it just pay the couple dollars for shipping.
Old May 30, 2007 | 07:42 AM
woolf's Avatar
Not to pry, but if you are thinking about adding a sub to your stock system, you should really just start princing a new system. With the Hi-lo converter it is very tough to have any control over the sub. My experience has always been overwhelming thumping noises and not music. JMO
