Radiartor fan speed question
Copying this question here since I'm not sure what section to write it under....
Hey guys, i have had my hands busy with this project for the last week; I am installing an A/C unit to my wrangler. it is originally from Canada and it didn't come with it.
i didn't notice until i drove it off the lot so after i tried and failed to have it returned, after i bitched, and after suing them for false advertisement, (vehicle feature disclosure said it came with AC), they paid me some cash so i could get it installed.
I am a cheap bastard, and very curious. also i hate people touching my cars, so i decided to do it myself.
i am basically done, but there's one more thing i have to do. i installed an aux electric fan to work whenever the compressor is on. but since this is a pusher fan, it isn't very efficient and i'm not getting the condensing pressures i want.
now to the question... when you start your AC in your Jeep. does the radiator fan come on LOW? HIGH? does it stay on the whole time? i have to tap into the fan circuit but i'm not sure if i should do the low speed circuit or the high speed or a mix of both. thanks for the help!
Question for you, did the wiring harness already have all the connections in it for the controls and compressor?
With A/C off, the fan will not come on when the engine is started until coolant temp reaches 215°F. It will remain on until the engine is cooled to about 195°F. Normally, on the road with A/C off, there is sufficient air flowing through the radiator to keep the engine cool enough to keep the fan off.
I think the fan comes on whenever the vehicle is started, AC or not, but only on low. I think the speed of the fan is tied to the coolant temp. That being said, you could get the dealer to program your TIPM to know that you have AC and the fan would come on when it is supposed to. I think the reprogram is less than an hour of labor. Question for you, did the wiring harness already have all the connections in it for the controls and compressor?
You can always do this: https://www.jk-forum.com/forums/modified-jk-tech-2/oem-mechanical-fan-retrofit-235132/
You can always do this: https://www.jk-forum.com/forums/showthread.php?t=235132
