Radio / Navagation shut off
Old 09-04-2011, 10:43 PM
Shortbuss's Avatar
My 08 has done this a few times. Cuts in and out then fixes itself. I can never figure out the problem.
Old 09-09-2011, 08:05 PM
geman's Avatar
My 07 just did it last monday, i am actually trying to find more inf about it. It started after a heavy rain, but cut off after leaving it in the sun all day. hasnt come back but i thought it might me water in a conector. will keep looking.
Old 09-09-2011, 08:12 PM
whpony96's Avatar
Originally Posted by snopro269
Recently experienced on my 2010 Rubicon of my radio completely shut off as I was driving on a perfectly paved road. Battery connections good, fuses good, no loose wiring found. I also disconnected the battery to reset everything as well. After pretty much giving up and deciding to bring into dealership the next day, The radio turned on and was working perfectly the next day. Anyone else experienced this? I am just over 10,000 miles and still under warranty but i think they won't find anything and was curious if anyone else has had this.
Hey snopro269 it sounds like you might have a hardware issue. If you take it into the dealership they can run a diagnostic on it and verify if it is hardware failing or software related. (I doubt it's software related since you installed the update.) You can also reinstall the update again without harm to the MyGig as well. (This has fixed some weird issues I have run into)
Old 09-09-2011, 09:06 PM
snopro269's Avatar
Yeah I doubt it's software because I have ran it over 6 months since Your last update and it's worked perfect without any issues.
I am going to bring it in on Monday and see if the dealership can find anything!!
Old 09-10-2011, 05:07 PM
Thrust's Avatar
My 2011 had this occur last week. It came repowered right away and no problems since. It did, however, reset my EQ settings.
Old 09-10-2011, 08:10 PM
snopro269's Avatar
Mine did that also about three times then now never returned back on
Old 09-11-2011, 04:56 AM
MarwanJeeper's Avatar
update ur gig and grancenote softwear its very easy setup to do, u need a cd for application update and DVD for gracenote.
visit (mofv.com/mygig/) but sure of type mygig u have.good luck
or u can ask the dealer to update the firmware.
Old 09-11-2011, 04:58 AM
snopro269's Avatar
I thought of that but since my radio don't turn on that's not going to happen
And yes I did check my fuses!!
Old 09-11-2011, 07:37 AM
09Rubix's Avatar
My 2009 Navigation would freeze frequently but never shut off completely. Had the radio replace 3 times under warranty twice for that reason and once for the dvd shutting off.
My 2011 has been much better but the steering wheel controls stopped working for 2 days and then began working again.
I hate how radios are only warrantied with refurbished units. The replacement seems to have more issues than the previous, so I'm hoping to not experience more audio problems.
Old 09-11-2011, 03:06 PM
snopro269's Avatar
If I have more issues with mine I'll probally just put a diff navigation in it
Quick Reply: Radio / Navagation shut off
