Radio question
Bought a 2016 JKU and it has an aftermarket radio it appears.
I haven't been able to find instructions anywhere. I can't figure how to set my damn radio stations. I have to turn the dial each time I turn it on. Yeah I know but it is irritating as hell. Actual radio picture https://cimg3.ibsrv.net/gimg/www.jk-...3a8428d031.jpg Only thing I could find online and is not available now https://cimg2.ibsrv.net/gimg/www.jk-...1385e8edb8.png |
You likely need to do more research. I am not sure that radio you have listed from Amazon is yours. One idea is pull your radio out and look at the tags for the unit. My search led me all over the place using the model number from Amazon. |
You can change the look of the face.
All the buttons down each side is the same......thanks I will keep looking or just turn the dial each time. Lol |
Try contacting the support lines for the ebay/amazon sellers and see if they can't provide a link to the instruction manual. If not, they should at least be able to connect you with the company they buy them from.
Sometimes buttons react differently when pressed. For example simply pressing the button will invoke one action while pressing and HOLDING the same button will often take one into a setup menu. I would try pressing and holding for 3 or 4 seconds if you haven't tried that already.
Hope this helps KG6SLC aka Eugene |
