RBZ and lockpick v. 3 - issue
I bought a MyGig RBZ and a lockpick v. 3 and so far I'm loving it... I do however have one issue...
I installed my backup camera today and when I pull into reverse it comes on like it's supposed to.. It works and looks great. However when I hit the UConnect button twice I still get the "UConnect Phone Not Available" message and not getting the camera feed. I've tried updating the firmware, resetting the switch positions all with no luck. I sent messages to Coastal before I purchased the RBZ and the Lockpick and they assured me that the Lockpick would work with any MyGig.
I need this functionality to work because I want to install a front camera as well (already have the camera) and have to use a very similar button sequence to get to that feed.
Has anyone run into this yet? Anyone have any suggestions?
Just in case anyone needs this info here it is..
08 Wrangler X
MyGig RBZ
Lockpick v 3 (switch 1 is down all others are up)
I've sent messages to Coastal as well and will update the status as soon as I hear back..
08 Wrangler X
MyGig RBZ
I have read in other threads that you need to go into your engineering mode and turn something off that you would normally have on to make uconect work properly. It's on another thread on this forum that someone had a similar problem.
