Rear Blinker issue
Old Dec 1, 2017 | 09:45 AM
WrenchBender142's Avatar
Default Rear Blinker issue
Apparently when I go to use my blinkers in my 2015 jku, both rear lights flash regardless of which directional I put on. Almost as if I was using the hazards, but the front is working normal. The only after market wiring done in the back is that I tapped into the ground and the park lamp wires to run for a new plate light. Other than that, it's all stock factory wiring. Any ideas?
Old Dec 1, 2017 | 10:22 AM
ronjenx's Avatar
Sounds like you may have tapped the wires incorrectly.
Disconnect the aftermarket wires, one by one, and see at which point the blinkers function normally.
Old Dec 1, 2017 | 06:51 PM
I tapped the wires 7 months ago. Issue didn't present until yesterday.
Old Dec 1, 2017 | 08:59 PM
ronjenx's Avatar
It would have been nice to read that in the first post.
Old Dec 2, 2017 | 04:57 AM
zstairlessone's Avatar
Oddly enough, disconnect your battery for 15 minutes, hook it back up and see if the problem goes away.
