Recomendations on Lighting
Old Apr 18, 2013 | 05:33 AM
jeme's Avatar
Looks like I can get the truck lites for about $440, any input on some of the "flickering" I am reading about? I have a 2009 Sahara. I also heard it effects different model years differently?
Old Apr 18, 2013 | 08:30 AM
Jkforlife's Avatar
The flickering is very shuttle and you can only tell when your facing a wall
Old Apr 18, 2013 | 09:09 AM
jeme's Avatar
Thanks, but should it be flickering at all?
Old Apr 18, 2013 | 10:13 AM
Evo35's Avatar
Originally Posted by jeme
LoJack where do you get the wiring harness? Do you have a link you can share please and thanks so much.
rallylights.com
Old Apr 18, 2013 | 12:05 PM
Macman1138's Avatar
It's really very faint, nothing really.
Old Apr 19, 2013 | 01:35 AM
Kojack's Avatar
They flicker because of the can bus system in the jeeps. I had hid in my jeep with are affected the same way, took it all back out because it was so annoying. The wiring harness is from Susquehanna motorsports. They do not have it listed, but have said they have them.
Plus if you live in an area with sloppy snow, do not get led headlights. They do not heat up causing the snow to build up and block lighting.
Old Apr 19, 2013 | 03:02 AM
jeme's Avatar
Kojack what are you using now since you pulled it all out. I never though trying to upgrade headlights could get so complex!
Old Apr 19, 2013 | 04:50 AM
Macman1138's Avatar
It's really not that bad. I may or may not get a new harness.
I wouldn't even call it a problem.
Old Apr 19, 2013 | 04:52 AM
Macman1138's Avatar
Originally Posted by Jkforlife
If your willing to make the upgrade, Led lights are way cheaper in the long run, I run trucklites and couldn't be happier with the quality of the light and coverage, they are 430 at rebel offroad for a pair
I love my Truck-Lites as well.
Old Apr 19, 2013 | 08:55 AM
Northridge4x4's Avatar
Sponsoring Vendor
I agree the flicker is not that bad but we do have a harness available that fixes that.
We have a ton of Trucklights in stock in both locations and can ship the same day and will get you the best deal
David
