Red Lightnin Bolt Help
Old Aug 10, 2011 | 05:10 PM
jagermeister427's Avatar
Default Red Lightnin Bolt Help
I have been getting a red lightning bolt on my dash recently, it comes and goes sometimes it will appear and when i restart it goes off sometimes for a day or a week... I had two codes pop up but my jeep runs fine... Anything to worry about????
Old Aug 10, 2011 | 06:08 PM
Gforce!'s Avatar
From: Independence and Lexington, KY (depends on the time of year)
The lightning bolt means that there's something wrong with the throttle control electronics. But only if it remains lit while driving. You're "supposed" to see your dealer about it because of reduced performance.
Old Aug 10, 2011 | 06:26 PM
ronjenx's Avatar
The obvious question now is: What were the codes?
Old Aug 11, 2011 | 03:03 AM
The two codes i got were p0221 and p2135. The light has been coming on everytime i drive now. No performance issues though. Any ideas. Thanks
Old Aug 11, 2011 | 03:27 AM
jdk's Avatar
jdk
https://www.jk-forum.com/forums/show...ighlight=p0221
This tread should help you out.
Old Aug 11, 2011 | 04:08 AM
I know what the codes say i just need some help on how to fix or if i need to go to the stealership
Old Aug 11, 2011 | 04:50 AM
ronjenx's Avatar
P0221-THROTTLE POSITION SENSOR 2 PERFORMANCE
  • When Monitored: Ignition on and No MAP Sensor DTCs set.
  • Set Condition: TP Sensor signals do not correlate to the MAP Sensor signal. Two Trip Fault. ETC light will illuminate. P2135 should set with this code also.
[TABLE]
[TR]
[TD="bgcolor: white, align: center"]Possible Causes
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: left"]EXCESSIVE RESISTANCE IN THE TP SIGNAL 1 CIRCUIT
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: left"]EXCESSIVE RESISTANCE IN THE TP SIGNAL 2 CIRCUIT
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: left"]EXCESSIVE RESISTANCE IN THE 5-VOLT SUPPLY CIRCUIT
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: left"]EXCESSIVE RESISTANCE IN THE TP SENSOR GROUND CIRCUIT
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: left"]TP SIGNAL 1 SIGNAL CIRCUIT SHORTED TO THE (K122) TP SIGNAL 2 CIRCUIT
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: left"]THROTTLE POSITION SENSOR/THROTTLE BODY
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: left"]POWERTRAIN CONTROL MODULE (PCM)
[/TD]
[/TR]
[/TABLE]
P2135-THROTTLE POSITION SENSOR 1/2 CORRELATION
  • When Monitored: With the ignition on and no other DTCs present for TP Sensor No.1 or No.2.
  • Set Condition: PCM recognizes TP Sensors No.1 and No.2 are not coherent. One trip fault and the code will set within 5 seconds. ETC light is illuminated.
[TABLE]
[TR]
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: left"]TP SIGNAL 1 SHORTED TO VOLTAGE
[/TD]
[/TR]
[TR]
[TD="bgcolor: white"]TP SIGNAL 2 CIRCUIT SHORTED TO VOLTAGE
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: left"]RESISTANCE IN THE TP SIGNAL 1 CIRCUIT
[/TD]
[/TR]
[TR]
[TD="bgcolor: white"]RESISTANCE IN THE TP SIGNAL 2 CIRCUIT
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: left"]TP SIGNAL 1 CIRCUIT SHORTED TO GROUND
[/TD]
[/TR]
[TR]
[TD="bgcolor: white"]TP SIGNAL 2 CIRCUIT SHORTED TO GROUND
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: left"]RESISTANCE IN THE 5-VOLT SUPPLY CIRCUIT
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: left"]5-VOLT SUPPLY CIRCUIT SHORTED TO GROUND
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: left"]RESISTANCE IN THE TP SENSOR GROUND CIRCUIT
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: left"]TP SIGNAL 1 CIRCUIT SHORTED TO THE (K122) TP SIGNAL 2 CIRCUIT
[/TD]
[/TR]
[TR]
[/TD]
[/TR]
[TR]
[/TD]
[/TR]
[/TABLE]
Old Aug 11, 2011 | 05:55 AM
Thanks for the help so far... But i have no idea what this means haha. Any other input... Thanks i really appreciate it. Dealerships suck
Old Aug 11, 2011 | 05:57 AM
ronjenx's Avatar
I guess your best bet is the dealer, then.
Old Aug 11, 2011 | 06:09 AM
Thanks so much for the help i guess i will go in and get robbed haha. I guess im gonna try removing the plugs on my TB make sure nothing is dirty
