Relay Kit solution for lights/CB/OBA/Winch ???
Ok so I'm looking to get this whole wiring deal done right the first time.
I'm looking at adding 2 pairs of lights, a CB, a winch in time, and an OBA system very soon.
My question is what is the complete wiring solution for all of this?
I figure I'll want to mount all the switches in one clean setup to the left of the steering wheel when its all said and done.
So this is what I'm assuming:
for each pair of lights:
painlessperformance.com/webcatalog/largeview.php?SearchField=30803
Winch/OBA and a pair of lights (if I'm supplying my own switches anyway and dont see the need to do the whole aux lights only come on when higheams are on) I could just use a 3 relay setup like this:
painlessperformance.com/webcatalog/largeview.php?SearchField=30107
they also make a 6 relay setup just fyi but its 300 bucks so I'd like to not spend that much.
for the CB and one other small assecory such as a hardmounted iPod:
http://www.quadratec.com/products/96080_98.htm
I'm totally clueless how this all goes together, I want to be able to turn on everything individually and turn off with the ignition. I'm looking for a very clean, factory setup on a budget that wont have any problems...expedition ready!
Thanks in advance guys!
Last edited by HappyCurmudgeon; Jun 18, 2009 at 05:16 AM. Reason: removed hyperlinks
Bottom line: I know there are some who really like lots of switches--I saw an awesome JK at JK-Jam where someone had spent big bucks nicely integrating dozens of switches that did who knows what (never met the owner). But, there are easier solutions to what you're asking for--if you don't mind a clean, easy install without lots of switches. Basically, I have nearly what you're asking for and all I needed to add was one switch and relay--and it came with the lights kit.
Last edited by HappyCurmudgeon; Jun 18, 2009 at 05:16 AM. Reason: removed quoted hyperlink
And the previous poster is correct regarding the amp draw on a winch. You would not want to relay it, just connect to the battery terminals and run the provided control.
Edit: ok, didn't know there was a problem referring to that particular product
Hmm.... anyway, there are companies out there that sell prewired relay boxes bundled with cooresponding switch banks. You'll have to do a little digging around online or better yet, make a trip to a local 4X4 shop and ask around.
No worries I know exactly what product you are talking about and I agree its holy shit expensive, definitely not going that route.
Sounds like the winch is its own stand alone deal...I'm definitely OK with that. using a remote works just fine for me
As for the switches I guess I'll only really be using 2 since I only plan on having two axu lights. Heck, I may even go with just one pair given the total cost ain't too cheap for the next pair...and really when do I need to shred that much light? It'll depend more on the style of bumper I go with...
Anyway I was just looking at the wiring kit that came with my IPFs and it asks you to splice into the headlights which I really dont want to do. Anyway I wired up everything except that part(is there a way to bypass it?) and the switch much less the lights dont light up. It may be a grounding issue but I need to quit for today. The lights look really good mounted up thought...
thanks for the insights guys, any more? I'm a bit confused at the moment.
That 12 volt guy makes some military grade stuff it looks like. I wasnt really going for that look but what the hell I like stuff that works well and is reliable...seems I might just give that guy a call and have him set it up however he thinks it'll work best. Pretty cool how its all custom. Prices seem reasonable too
I have made my own solution... Under $200 and very easy to make. But like they said, go stand alone for the winch purely due to the amperage it will draw. My system can be adapted, but you'd have to buy the right solenoid and from my previous research, it is close to $75...
here's a link: https://www.jk-forum.com/forums/jk-write-ups-39/ef-s-pod-51938/
wow 220 for a dual battery tray...what the heck? Its not like I will be using all of this all at once with the battery off. Arn't most people getting along just fine with one battery? Didnt the JK come with a better alternator?
I really like Zoomzooms setup, simple, durable and effective. 12voltguy is putting together a mock up for what I'm thinking I'll need long term
