remove dash
Old Sep 9, 2008 | 09:59 AM
jgapril's Avatar
Default remove dash
Hi all.
Well I am just about to run all my wiring for my lights, siren, ext speakers, and sign to my switch panel. What I really need to know and see is how to remove the dash panels to run the wires. I can get the wiring inside the cab, but what then. PICS WOULD BE FANTASTIC.
thanks
John
Old Sep 9, 2008 | 06:05 PM
Frog Rubicon's Avatar
Posted by SONIC:
You need to just pull the bottom piece off (after the shifter bezel) it will just come out. then remove the top panel with a screw driver (pry it) and there are some screws. once you remove those grab it by the AC vents and just pull and it should come out.
